mpc28
Nov 11, 2022Aspirant
HELP PLEASE - Netgear WNDR 4500 N900 - Internet LED Not lit?
I have recently acquired a Netgear WNDR4500v1 N900 from Ebay as an upgrade to my current Netgear WNDR3700v4. My broadband provider is Virgin Media and I have the HUB3 router, it is set so wifi is tu...
mpc28
michaelkenward I have enabled 'modem' mode in the HUB3.
Ideally I would prefer a Netgear router that still uses the genie web interface as that is what I'm familiar with. Which 'newer' Netgear router would you recommend?
Is the AC type wifi router newer that the N type?
Is the R6300 AC1750 any good?
wcalifas
Nov 11, 2022Prodigy
Reset the wndr4500 when powered on, press the reset pinhole with paper clip for 30 seconds and see if that helps. Then after the reset connect the ethernet cord to the internet port on the wndr4500.
