maxikensega29
Feb 27, 2022Follower
Help setting up my netgear router
I just got FIOS turned on today, I've spent hours on hold over the past few days. I have a brand new netgear ac1600, but I can not get it to see the internet. If I plug my laptop directly into the ...
michaelkenward
Feb 28, 2022Guru - Experienced User
maxikensega29 wrote:
I just got FIOS turned on today, I've spent hours on hold over the past few days. I have a brand new netgear ac1600...
Which model is that? AC1600 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Netgear hasn't made that many AC1600 routers.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
If I plug my laptop directly into the ONT ...
Does that have a make and model?
