dorismc
Feb 09, 2024Aspirant
Help with setup older router as acess point/extender
I am trying to set up a Netgear N600 wireless dual band router WND3400 as an acess point or extended wireless. I want to put this router out in the RV which is close t my wireless cameras. I k...
dorismc
I had an almond securifi https://www.securifi.com/rg/softwareupdate-almondplus that worked perfectly. The menu on that device got messed up and I can't click on letters or numbers to connect it again. That is why I know the older router with the right setup would work. The wireless of the netgear will reach my Zytel wireless modem in the house..
Feb 09, 2024Guru - Experienced User
You can always look at some other posts about it. Thats an very old router. I haven't messed with one in years.
You might be better off picking up a half decent wireless extender that is designed for the purpose you're looking for
- dorismcFeb 09, 2024Aspirant
Thanks but those links don't explain anything and menus don't seem to match what this router has. I figured it has 5G so it had capabilities.
- FURRYe38Feb 09, 2024Guru - Experienced User
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
If you don't see any Extender or Repeater mode options with in the routers WEB UI pages, then you can presume this modem router doesn't support those features.
