Eckerman's avatar
Eckerman
Follower
Jul 07, 2022
Help with WN3000RPv3
My WN3000RPv3 is already set up in a remote area of my house WITH ITS OWN WIFI NAME. The WN3000RPv3 links cameras/generator to my regular wifi that connects to Internet. I have just changed my regular wifi with new wifi with a new wifi name/password. How do I change my WN3000RPv3 to link to the new wifi with new wifi name? I don’t want to reset WN3000RPv3 to factory if possible. (I’m not too technical so please give me simple steps to follow. Thank you, eckerman
1 Reply
  • plemans's avatar
    I actually would reset it to factory. Just write down what its current ssid/password is so when you reinstall it, you can set it back to what you had so everything just auto-reconnects.
    Probably be the fastest option.
    otherwise you can try connecting to it and re-running setup within the installation assistant
