cfj4462
Jun 15, 2016Aspirant
High Operating Temp Environment
I am looking for a reasonably priced wireless router that can handle temps above 120 degrees. All cabling for the house is in the garage, in LHC AZ, a very hot place in the summer. I could do a fir...
- Jun 23, 2016
Thank you everyone for your input.
I ended up purchasing a Mikrotik RouterBoard RB2011iL-IN (wired router) for the garage. It is rated at 149 degrees.
I purchased a WNDR4300V2 wireless router for in the house.
It was 116 degrees out the other day, it was 106 degrees in the garage.
Everything is working fine.
cfj4462
Jun 16, 2016Aspirant
I agree a fan would help, how much in a 120 degree environment, I'm not sure.
avtella
Jun 16, 2016Prodigy
Go with one of the Qualcomm based routers like the R7800 or R7500v2 they run much cooler than the Broacom based ones like R8000 and to top it off the qualcomm CPU is much more powerful per MHz and its actually clocked higher on top of that. I did use a WNDR3800 a few years ago abroad where temps hit towards your range and it was fine so if you want a garunteed/tested one this would be it but it is a much older device lol.
