cfj4462
Jun 15, 2016Aspirant
High Operating Temp Environment
I am looking for a reasonably priced wireless router that can handle temps above 120 degrees. All cabling for the house is in the garage, in LHC AZ, a very hot place in the summer. I could do a fir...
- Jun 23, 2016
Thank you everyone for your input.
I ended up purchasing a Mikrotik RouterBoard RB2011iL-IN (wired router) for the garage. It is rated at 149 degrees.
I purchased a WNDR4300V2 wireless router for in the house.
It was 116 degrees out the other day, it was 106 degrees in the garage.
Everything is working fine.
cfj4462
Jun 23, 2016Aspirant
