husinlove490's avatar
husinlove490
high ping on R6100
Hello.. i have netgear router R6100 The problem is the ping is so high like 300-200 And when I connect as wired to computer its back to 5-8 what is the problem?
  • William10a's avatar
    William10a
    Sep 04, 2017
    Is the qos on or off have seen postings about qos cause iusses with wifi.
    Try turning the qos off.
