husinlove490
Sep 03, 2017Aspirant
high ping on R6100
Hello.. i have netgear router R6100 The problem is the ping is so high like 300-200 And when I connect as wired to computer its back to 5-8 what is the problem?
- Sep 04, 2017
Is the qos on or off have seen postings about qos cause iusses with wifi.
Try turning the qos off.
William10a
Sep 04, 2017Master
If your wifi connection is the one with the problem then interference from other routers, possible issue with the wifi enable device since you said a wired computer has only a 5-7 ms lag time
husinlove490
Sep 04, 2017Aspirant
I tried with another routers many of them ping is normal 5-8ms
- William10aSep 04, 2017Master
- husinlove490Sep 04, 2017AspirantI just turn off WMM ( WI-fi multimedia)
And its work for me😁😁😁ping back to high
