Dyn0saur
Mar 10, 2022Tutor
How can I find the IPv6 prefix?
I have the prefix length but not the prefix. I need the actaul prefix to finish setting up my NAS. Thank you.
- Mar 10, 2022
Should look similar to this:
Mar 10, 2022Guru - Experienced User
Not sure exactly what you're referring to or what issue you're running into.
You put wndr3700 as your router but that you're setting up a nas.
Where exactly is the issue?
Dyn0saur
Mar 10, 2022Tutor
plemans wrote:Not sure exactly what you're referring to or what issue you're running into.
The NAS requires the prefix to complete VPN setup. I can't find the prefix, only the prefix length.
