Dyn0saur
Mar 10, 2022Tutor
How can I find the IPv6 prefix?
I have the prefix length but not the prefix. I need the actaul prefix to finish setting up my NAS. Thank you.
- Mar 10, 2022
Should look similar to this:
Dyn0saur
Mar 10, 2022Tutor
Mar 10, 2022Guru - Experienced User
the router's ipv6 address?
That should be on the IPv6 setup page
- FURRYe38Mar 10, 2022Guru - Experienced User
- Dyn0saurMar 10, 2022Tutor
That's it! Thank you.
FURRYe38 wrote:Should look similar to this:
https://networklessons.com/ipv6/how-to-find-ipv6-prefix/
Good. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
