Retired_Member
Dec 07, 2025How can I purchase a PAV12V25 power adapter?
I can see this adapter on the Netgear website, but I can't see where to purchase one.
Retired_Member
Dec 07, 2025Amazon was one of the first places I looked. I found plenty of power adapters, but I did not find this exact model.
Dec 07, 2025Guru - Experienced User
lprobert wrote:Amazon was one of the first places I looked. I found plenty of power adapters, but I did not find this exact model.
Are you sure the PAV12-100NAS won't work. It has the same specs. Maybe check the compatibility list on Amazon.
- Retired_MemberDec 07, 2025
I need a power adapter that has the prongs in the same direction as the PAV12V25, i.e., horizontally instead of vertically relative to the body of the adapter. That's so it'll fit on my BackUPS.
- CrimpOnDec 07, 2025Guru - Experienced User
Netgear:
Amazon has several similar products. Here's one:
When my UPS or power strip has too many power blocks to fit comfortably, I often use a short extension cable, such as this:
There are several on eBay. I was a bit surprised at how much people are asking for them.
