sajib_siddiquei
Mar 10, 2017Follower
how can I watch my media content from the hard disk attached in the router to my smart tv
i have a netgear n600 router (WNDR3400) in which i have connected a portable hard disk. now I would like to access the hard disk from my samsung j5500? is there any way for it? i want to access it di...
- Mar 10, 2017
It looks like your Samsung can stream from a DLNA server. Unfortunately, the WNDR3400 doesn't support DLNA. Some of the newer Netgear routers do.
Try connecting the hard disk directly to the TV's USB port.
TheEther
Mar 10, 2017Guru
michaelkenward
Mar 11, 2017Guru - Experienced User
TheEther wrote:Try connecting the hard disk directly to the TV's USB port.
That's the best way to do it. Even if your router supports DLNA it can be a pig to configure on a TV. And USB will always be faster, especially if your TV uses wifi anywhere in the chain.
- TheEtherMar 11, 2017Guru
USB is best for streaming to the TV but it'll be a pain to move the hard disk back and forth between the TV and a PC in order to put more movies onto it. The next best thing is to get real NAS with a built-in DLNA server.
- michaelkenwardMar 11, 2017Guru - Experienced User
TheEther wrote:USB is best for streaming to the TV but it'll be a pain to move the hard disk back and forth between the TV and a PC in order to put more movies onto it.
Depends on how often you need to move the USB drive, and if you are prepared to pay >£100 to buy an empty NAS enclosure. Add another £100 or so for drives and that would buy plenty of USB space.
- StephenBMar 14, 2017Guru - Experienced User
While a ReadyNAS isn't the cheapest solution, I find it much better than shuffling USB drives.
If you pick a platform capable of transcoding, then the NAS can also help with media compatibility (allowing you to play DTS audio w/o an AV receiver turned on, etc).
