kennybee's avatar
kennybee
How can you reduce router wireless signal strength?
How can you reduce wireless router signal strength?  If so, what routers allow you to reduce wifi signal strength? How?
  • TheEther's avatar
    Jan 23, 2016
    Some routers have a radio transmit power setting.  The R7000 has such as a setting.  Other Netgear models may also have it.
    Another option is to load 3rd party firmware, such as DD-WRT, Tomato and others.  They should all have radio power settings.  Not all routers support 3rd party firmware.  Check the respective firmware websites for details about supported models.
