Lostboy's avatar
Lostboy
How do I Access home network without internet
I have a extended home network (16 componants) all hardwired through 20 port Netgear hub and eveything runs perfect.
Shouldn't I be able to access my home network without internet access?
  • > [...] extended home network (16 componants) [...]
       What's a typical component or two?  What are we talking about?
    > [...] 20 port Netgear hub [...]
       Not a very detailed description of anything.  Model number?
       You should, depending on what "access my home network" means to you.
    So long as the LEDs show good connections, and everyone has a good IP
    network configuration, then any device should be able to talk to any
    other device on your LAN.
       What, exactly, are you trying to do, and what, exactly, happens when
    you try?
       If there's no router or other DHCP server in the network, then every
    device would need to have a static IP address (because there'd be no
    DHCP server to assign an address dynamically).  Beyond that guess, some
    actual information might help your inquiry.  Your message suffix
    mentions an R6250.  Is that involved somehow?
1 Reply
    you try?
