Karjiana
Oct 25, 2023Follower
How do I add my new wifi network onto R6230 router
I just switched ISPs and just set up the modem and can't add the new Wi-Fi information onto my existing Nighthawk app. Does anyone know what I'm supposed to do?
michaelkenward
Oct 26, 2023Guru - Experienced User
When you change ISPs, you need to get your devices to forget any settings from the old ISP. The easiest way to do that is to reset the router and set it up from scratch.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
