varxtis
Jan 13, 2016Aspirant
How do I assign Static IP Address to a device? (XBox One)
I'm trying to set up my XBox One for remote streaming but Im completely ignorant when it comes to networking and rely hevily on default settings. There seems to be three main parts to this process described here:
- Port Forwarding (which has been explained by DexterJB. Thank You!!)
- Assigning a Static IP Address to the Device (This Step)
- and setting up Dynamic DNS
I was wondering if anyone would be willing to walk me through the step of assigning a Static IP Address to a device, which in this case is my XBox One.
I've actually wanted to know this for a while for other devices, but don't know if its a router thing or a computer thing. I'd appreciate any help.
Hi @varxtis,
You are welcome!
Instead of setting a static IP for your XBOX, you can perform address reservation so that the XBOX will have a consistent IP address for the port forwarding that you have performed. You may refer to the link below for the steps on how to do it.
http://kb.netgear.com/app/answers/detail/a_id/24091
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi @varxtis,
You are welcome!
Dexter
Community Team
- varxtisAspirant
So, basically, Im just using the IP it's already been assigned (in the case of the XBox its 192.168.1.3) and not establishing a new/custom one, right?
- Retired_Member
yes and no you could change it in reservations and then power cycle Xbox to get new IP
