FGG
Oct 18, 2021Aspirant
How do i change authentication algorithm from CHAP to MS-CHAPv2? Model N 300 JWNR2000v2
Hello. My ISP messaged me, that they will change authentication algorithm from CHAP to MS-CHAPv2 soon, and asked me to check my router settings to make sure it's on AUTO mode. But i couldn't fin...
- Oct 19, 2021
But i couldn't find anything like this. Does my router even have that function and compatible with MS-CHAPv2?
The JWNR2000v2 is an old (2011 and based on a 2009 model) that was never that sophisticated.
This seems to be more likely to be a modem level setting. And LTE modems at that.
A quick search of Netgear's manuals suggest that "CHAP" is for network hardware, such as switches, or LTE Modems.
And the LBR20 4G LTE WiFi Orbi Router and WBC502 are two of three devices that even mention MS-CHAP.
Which ISP is this?
Oct 18, 2021Guru - Experienced User
If that feature is not listed in the web page or user manual, then I presume this model router doesn't support it.
Usually thats a hire level authentication system used in other platforms like MS and such.
