RT2032
Mar 29, 2016Aspirant
How do I change channel on a DG834PN please
- Mar 29, 2016
Thanks for the link unfortuanatly being a'silver surfer' I cannot understand the jargon.
I have been having trouble with loss of signal my ISP suggested I change the channel on my router but I am completly lost!!!
RT2032
DexterJB
Mar 30, 2016NETGEAR Moderator
Hi @RT2032,
1. Access the device UI. You can use the IP address or by typing www.routerlogin.net on the address bar of your browser.
2. Default logins will be admin for the username and password for the password not unless you have changed the default password.
3. Select the "Wireless Settings" option on the left.
4. You will then find the option to change the channel.
Dexter
Community Team
