caroledickson13
May 09, 2022Aspirant
How do I change my password?
I think we have been hacked. Using more data than we possibly could. Can someone tell me how to change my password? I have looked everywhere. Thanks.
caroledickson13
Hi, thanks, I'm trying to change the network key password that was assigned from the factory. When I go to that website you posted it won't let me sign in. Says its not secure. My router is R6220.
Thank you so much for your help.
May 09, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to 192.168.1.1 or routerlogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on. Then go in and configure the SSID name and give a new PW here.
- plemansMay 09, 2022Guru - Experienced User
How much data are you using?
Do you do streaming?
Streaming in 1080p or 4K?
A lot of people think they've been hacked when many times its something on their networks actually using the data.
