Spica's avatar
Spica
How do I change the GUI password on my WNDR3700v4 router?
Hello, I would like to change the GUI password on my Netgear WNDR3700v4 router. Can I do that on the router interface page, or is that done elsewhere? Thanks!
  • Spica's avatar
    Spica
    Apr 04, 2019
    Thanks for your help. It worked! So we can't change the user name - I see. That was my next question, which you anticipated. Thanks again!
