Spica
Apr 03, 2019Aspirant
How do I change the GUI password on my WNDR3700v4 router?
Hello, I would like to change the GUI password on my Netgear WNDR3700v4 router.
Can I do that on the router interface page, or is that done elsewhere?
Thanks!
- Apr 04, 2019
Thanks for your help. It worked! So we can't change the user name - I see. That was my next question, which you anticipated. Thanks again!
michaelkenward
Apr 04, 2019Guru - Experienced User
Remember, you can change the password but not the username.
Spica
Apr 04, 2019Aspirant
- michaelkenwardApr 04, 2019Guru - Experienced User
It is a common request. Didn't want you to waste your time trying to fix it.
