BobBax
Oct 26, 2020Aspirant
How do I configure 2 EX2700 range extenders on the same network?
BobBax
Oct 27, 2020Aspirant
Thanks for the response. I agree that I do not want to daisy chain them. I have not been able to connect the second extender to the router. The New Extender Setup will ot come up again to connect the second extender.
Oct 28, 2020Guru - Experienced User
power off the first connected extender. Then factory reset the extender that won't connect (push and hold reset for 7-15 seconds while powered on). Then attempt to setup the 2nd extender.
Are you using wps or using the installation assistant?
