TonyR57's avatar
TonyR57
Follower
Aug 14, 2016
How do I connect my existing Netgear Router to a new computer?
  • michaelkenward's avatar
    michaelkenward
    Aug 15, 2016
    Wired is best.
    If you look at the manual, there is a diagram on page 5. (That's the copy I downloaded.) "Getting to Know Your Wireless Router".
    Plug a LAN cable into the computer and the other end into one of the orange LAN sockets.
    Otherwise, follow the computer's instructions for connecting by wifi.
