TonyR57
Aug 14, 2016Follower
How do I connect my existing Netgear Router to a new computer?
- Aug 15, 2016
Wired is best.
If you look at the manual, there is a diagram on page 5. (That's the copy I downloaded.) "Getting to Know Your Wireless Router".
Plug a LAN cable into the computer and the other end into one of the orange LAN sockets.
Otherwise, follow the computer's instructions for connecting by wifi.
geekgrl
Aug 14, 2016Aspirant
You can connect by wire or look up the wifi from the computer and connect to it.
michaelkenward
Aug 15, 2016Guru - Experienced User
Wired is best.
