degutisr
Nov 14, 2020Follower
How do I connect my Orbi06 to MyQ garage door openers?
Unable to connect new Orbi router to MY Q garage door opener. Your helpful assistance would be greatly appreciated.
Nov 14, 2020Guru - Experienced User
What orbi do you have?
What firmware is on it?
did you contact MyQ for assistance with installing their device?
Also, when setting up the myq, make sure your phone is on the 2.4ghz band. You shouldn't need to do this but lazy coding has meant that you need to be on the same wireless band the smart device is when setting up.
