KED1
Sep 28, 2021Aspirant
How do I connect my wifi range extender to my nowtv router? It doesn’t have a WPS button
Sep 28, 2021Guru - Experienced User
What extender did you buy?
There is a netgear installation assistant you can use instead of wps.
here's the video of how to use:
https://www.youtube.com/watch?v=yJVklshxBMk
you can also go to netgear.com/support/
type in your model number and it'll take you to install guides, manuals, firmware, etc.
