JohnnyChristo's avatar
Dec 10, 2020
How do i connect to hotel portal to bridge a N600
Hi thanks for reading I live in an appartment block. It has a portal login. I wish to configure my router so it logs into the portal and shares the wirless to my various items like my PC home googl...
  • plemans's avatar
    Dec 11, 2020
    You need a router that supports wisp mode.
    https://wifi-settings.com/wireless-routers/wisp-mode/
    That route doesn't support wisp mode.
    Netgear made one years ago but its out of date.
    I'd recommend looking for travel routers or even just searching for a router with wisp mode
