noisydaddy
Sep 03, 2016Aspirant
How do I get gigabit speed to my cable modem?
Hello, all, I just installed my new Nighthawk X4S router. Downloaded the latest formware update in the process. It is connected to a Motorola MB7420 cable modem for access to Comcast. Both of the...
- Sep 03, 2016
Log into your X4S and click on Show Statistics in the Advanced tab. If the status of the WAN port shows 1000M/Full, then you are golden. Otherwise, check your cable; cables can go bad.
TheEther
Sep 03, 2016Guru
noisydaddy
Excellent! thank you!
