RedIndianRobin
Dec 22, 2017Aspirant
How do I make my router to automatically connect to the internet?
Hey all, So my new router came in yesterday and I set it up today. Thing is, it works fine. It connects to the internet when I provide my ISP username and password. However, the issue is, I can't...
- Dec 23, 2017
RedIndianRobin wrote:
Does Netgear routers even have this feature of connecting automatically to the internet?Yes. If they are set up correctly. That is why I pointed you at that page in the manual.
As you have added a new router to your modem, you may need to go through the network setup process again.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
michaelkenward
Dec 23, 2017Guru - Experienced User
We'll have to wait for the screenshot to get approved.
The WNR614, as in your "footer", is a router. So what is your modem?
There is a manual for the device somewhere at the end of this link:
>>>> WNR614 | Product | Support | NETGEAR <<<<
I assume that you have set the correct Connection Mode. See page 20.
RedIndianRobin
Dec 23, 2017Aspirant
So why is my screenshot not getting approved? And yes, I did exactly what's said at page 20. My modem is a Optilink(provided by the ISP) not sure about the model though. Modem is perfectly fine as it automatically connects with other branded routers.
I'm still suffering from the problem though. I have to manually connect to the internet everytime I shut the router down. Does Netgear routers even have this feature of connecting automatically to the internet? Somebody pls help.
- michaelkenwardDec 23, 2017Guru - Experienced User
- RedIndianRobinDec 23, 2017Aspirant
Wow! So I did it in the given sequence and it actually works. The router now connects automatically to the internet IF I turn on the router AFTER my modem completes the boot sequence. Earlier, I switched on my modem and router at the same time and was having this issue. So am I suppose to always follow this sequence for the router to automatically connect to the internet? Thanks for you help BTW.
That's not how it tells you to do things in the Installation Guide which is also available at the end of the link I provided. It may also be in the box that the router came in.
So am I suppose to always follow this sequence for the router to automatically connect to the internet?See the Installation Guide.
