JohnnyWB
Sep 14, 2015Tutor
How do I remove users from my Wi Fi and block them on a Netgear N600 Model # WND3400V2?
I now have way to many people that can access my wifi network and I want to remove them. They uneccessarily clog my system and keep me from using my own network most times and talking to them is use...
- Sep 15, 2015
JohnnyWB wrote:So, if I changed the SSID and password, all those that are logged on will no longer be able to get on unless I allow them?
They will need the password to get on.
The SSID is just another tweak. It means that they will not see the same wifi network that they used to login to the network. You don't really have to change that. The important thing is to get a new "passphrase".
You should also ensure that you have security set to demand a wifi password. Some modem/routers allow you to create open networks that anyone can join. You don't want the security options set to "None".
The manual for your modem explains all this. Look at the section "Guest Network Wireless Security Options".
JohnnyWB
Sep 14, 2015Tutor
michaelkenward
Sep 15, 2015Guru - Experienced User
