Anconstevo's avatar
Anconstevo
How do I see what port my devices (cameras) are using with a WNDR4500 router?
How do I see what port my devices (cameras) are using with a WNDR4500 router?  I need to know the Port the camera is using so I can see it from other software.
  • VE6CGX's avatar
    Apr 29, 2016
    From your camera config. Camera has default port if you did not change it when you set it up. I don't know what camera you have
    but every camera has conffig page. In my case I use Synology surveillace station which shows port # readily(this chageable).
