AwesomeGuy20017
Oct 05, 2021Initiate
How do I setup my WNDA3100v3 adapter without any internet
I recently started building my PC and I bought a WNDA3100v3 wifi USB adapter per my friend’s recommendation. My problem is I can’t use Ethernet so I can’t access the internet without wifi but since I didn’t get any CD with my adapter I have to go to netgear’s website to install the software. I can’t do this if I don’t have internet though I do have another PC downstairs but I’m not sure if I could set up the adapter on it and then after it’s set up use it on my PC? I said I can’t use Ethernet because my router is across my house and downstairs so it really isn’t an option for me.
Please visit and post about this over in the WiFi Adapters forum?
https://community.netgear.com/t5/WiFi-Adapters/bd-p/home-wifi-adapters
Thank you.
you can download it and put it on a jump drive/flash drive. use that to install it to the PC.
WNDA3100v3 | Product | Support | NETGEAR
Indeed. Use the downstairs PC or ask one of the friends you mention to put it on a USB stick.
I'm surprised that you got your hands on a WNDA3100v3. It came out in 2014.
- AwesomeGuy20017InitiateThey’re on Amazon that’s how I got it
