Horizon55
Aug 02, 2021Follower
how do I uninstall Advanced Tomato back to Netgear stock
Please as I am Autistic please make it as easy as possible thank you
Aug 03, 2021Guru - Experienced User
antinode is correct.
3rd party firmwares can have different ways of removal based on what you installed.
the best people to help are the sames ones that helped install it. So go to the forum you found out how to install it and they should be able to help uninstall it.
You might end up in worse troubles by having the people who aren't using 3rd party firmware trying to help you.
