breannaw
Feb 28, 2024Aspirant
How do you reset Network Key? R6260
I’m trying to reset the password to my NETGEAR router and I’m not sure how.
breannaw
Just the password. I have a password on the back but it’s not working so I wanna reset it.
Feb 28, 2024Guru - Experienced User
The WiFi SSID name password or the admin log in name credentials?
Are you able to get into the routers web page by logging into the web page using Admin and current password there?
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
- breannawFeb 28, 2024AspirantI haven’t tried that no. Im not sure where that even is. I feel a little lost. Is it the NETGEAR home page?
- FURRYe38Feb 28, 2024Guru - Experienced User
If you cant' get logged into the router web page, then wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.1.1 using a wired PC and web browser and walk thru the setup wizard. Be sure write down all important information for safe keeping later on.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface- breannawFeb 28, 2024Aspirant
Okay I will try it right now and see if i can figure it out.
