tj11354's avatar
tj11354
Initiate
May 18, 2022
How does R6250 V1.0.4.48_10.1.30 get its time?
The time is always wrong after a reboot. This is the log:
[Internet connected] IP address: xx.xx.xx.xx, Wednesday, Dec 09,2020 11:14:01
[Internet disconnected] Wednesday, Dec 09,2020 11:14:00
[Initialized, firmware version: V1.0.4.48_10.1.30] Wednesday, Jan 01,2003 00:00:05
I schedule the WiFi to turn off/on at certain times, so the router must have the correct time. But I see no options for setting the time or pointing to an NTP server.
  • tj11354's avatar
    tj11354
    May 19, 2022
    Mea culpa! Didn't think the NTP setting would be under Schedule of all places. Expected it to be under Internet Setup. Now the time is correctly synced!
    [Time synchronized with NTP server] Thursday, May 19,2022 08:47:12
    [Initialized, firmware version: V1.0.4.48_10.1.30] Thursday, May 19,2022 08:47:06
  • michaelkenward's avatar
    michaelkenward
    Nothing here?
    • Settings
    • Advanced
    • Administration
    • NTP Settings
    What modem sits in front of this thing?
    • tj11354's avatar
      tj11354
      Initiate
        michaelkenward
        These things can get moved around when Netgear updates firmware.
