Melyssa
May 18, 2021Initiate
How install Netgear Genie for R6300v2 router?
Hi, I have a R6300v2 router and due to a recent hard drive failure, need to reinstall Netgear Genie on my new hard drive. Unfortunately, every time I click download on the version for Windows, the...
- May 19, 2021
I just tried it with my pc.
https://www.netgear.com/support/product/Genie.aspx#download
no issues downloading it.
Try a different web browser.
also, you don't have the use the genie to access the router. You can log into it using the browser.
Melyssa
May 19, 2021Initiate
Thank you very much for your help. It worked this time and I think the issue was that my computer wasn't giving me a message that it was a rar file and needed to be unpacked. Thanks again. :)
May 20, 2021Guru - Experienced User
Glad it worked!
If you mark it solved,it might help the next person as well as others won't try to fix a "solved" post.
