Marccroissette
Nov 08, 2020Aspirant
HOW MANY MBPS CAN MY ROUTER HANDLE
I just upgraded to 600 mbps, but my spead test won't show above 400? can my router handle this speed?
Nov 09, 2020Guru - Experienced User
The key is who the isp is.
Their certifications vary for which speeds.
For example, cox is starting to require docsis 3.1 for speeds greater than 150mbps.
- MarccroissetteNov 09, 2020AspirantXfinity in nj. I have 600mbps plan
- plemansNov 09, 2020Guru - Experienced User
The xfinity site shows the C6300 is rated for up to 360mbps plans.
