Kuttoosssan
Jun 05, 2020Aspirant
How much data transfer speed should I expect from Netgear r6400v2 using SSD on usb 3.0 ?
Router - R6400v2 SSD - Samsung T5 500GB Cable - Cat 6 How much speed should I get while transferring from PC to SSD via Ethernet? This is what I get on LAN Speed test, (attached photo) ...
- Jun 08, 2020
Kuttoosssan wrote:Thank you for the reply.
Is this because the actual router capacity is limited?
Or is it a firmware limitation?
It tends to be a hardware limit. When you start needing faster speeds, you need the hardware designed to run it and not a router with the included funcationality.
Kuttoosssan
Jun 08, 2020Guru - Experienced User
