atempo
Oct 25, 2019Aspirant
how to access router os?
hi, i'd like to access router os directly.... but there is just configuration web page... i guess.. cuz, there are few ip that i don't want to connect... so, i want to delete them all.... Is ...
- Oct 25, 2019
> [...] i'd like to access router os directly.... [...]
Which "router"?
> [...] cuz, there are few ip that i don't want to connect... so, i want
> to delete them all....I don't know what any of that means. Do you?
> [...] Is there any method that resolve my problem...?
I have no idea what your "my problem" is.
> Model: EX6150|AC1200 WiFi Range Extender
That's not a router.
Some Netgear router models (with some firmware versions) can allow
shell access using a Telnet connection. A Web search for terms like:
Netgear Telnet enable
should find some programs which might help. (I use the program which I
modified: http://antinode.info/nte/ ) But I would not bet that such
access will help you to solve whatever your actual problem might be.
antinode
Oct 25, 2019Guru
Which "router"?
atempo
Sorry, my bad..
I mean this one
'N300 WiFi router '
I mean this one
'N300 WiFi router '
