Chidion2083
Feb 26, 2021Follower
How to activate 5G on N600 WiFi Cable Modem
My Netgear N600 WiFi Cable Modem Router is not displying 5G. How do I activate the 5G on the router?
Feb 26, 2021Guru - Experienced User
How do you know the 5ghz isn't broadcasting?
What device are you testing this on? Does it have 5ghz built into it (the device)?
What are the led's on it showing?
What actual router is it? N600 is a speed.
If its a cable modem/router then you'd probably want to post in that forum and not the general router forum.
