bugmenot2
Dec 22, 2020Apprentice
How to avoid subnet with JWNR2010v5
hello, I have now read countless threads about this, but this seems to not work whatever I do. I have bought a JWNR2010v5 and I would like to use it as a second access point to extend my wireless ...
- Dec 26, 2020
downgraded firmware to v54 -- everything works as expected now!
the 403 Forbidden bug was quite annoying and, I guess, was what made me stray from the suggested steps in the tutorial.
schumaku
Dec 26, 2020Guru - Experienced User
antinode wrote:My guess is still that it will work properly if the provided
instructions are followed.
Disabling DHCP (as designed when operating as a router) seems to be workable - the DNS capturing remains (as on many elderly Negear routers) still in place.
bugmenot2
Dec 26, 2020Apprentice
antinodethanks for replying, but I would appreciated less aggressiveness.
if I forget to write "address" in IP address, you do not need to link Wikipedia articles back to me.
also, I don't need to be reminded that an Ethernet cable has two ends.
saying stuff like "you connect the LAN cable only?" is a way of saying that IF YOU connected the LAN cable only, THEN... which is not lost in translation ("tooth ache? use sensodyne.") so please be more patient.
in any case, schumaku makes great points.
it very well might be that you solved the futuristic firmware version riddle, thanks for that!
I will definitely not downgrade to the last version available on Netgear website, then.
> This makes it impossible using these crap routers as plain access points - say thank you Netgear
> for the bugs, and don't shoot the messenger...
I came on the forum precisely to have access to this kind of community wisdom.
if that is the case, that is, that a bug prevents a simply setup of AP mode, then there is not a lot I can do, I'll leave the full second subnet.
do you have any more info on that? e.g. a thread that discusses this bug for other routers?
I might read through and understand whether I'm observing the same symptoms.
precisely, the DHCP part is (well, might be) fine but I fear there is something wrong with the DNS queries.
I might use the wrong technical terms for this, that's why I opt for "feelings".
still, I am not an idiot and I understand I am talking to fellow customers, and thanks for that!, not customer support.
I will definitely remember this before buying another Netgear product though...
hopefully I'll retry once again following all the steps and I will report here once I do.
- schumakuDec 26, 2020Guru - Experienced User
It's tricky to find issues when things apparently change in a L2 bridge. One could only proof that by running a DNS query on a wireless connected system and check if the query does show up outside. Simply run a nslookup google.com and see what happens...
Worth mentioning: It's not a Netgear's issue if people are buying products not supporting a feature my friend.
- bugmenot2Dec 26, 2020Apprentice
well, I'm not trying to use an access point as a router, but the other way around.
it's a smaller subset of features, so it would be trivial to support, worst case a few lines here and there in the firmware.
I'm not asking for much.
anyhow, I'm trying again.
1. I've reset the Netgear,
2. I've disconnected all cables,
3. I've reconnected the power cable,
4. I've connected one laptop to one of the LAN ports on the Netgear,
5. I've opened 192.168.1.1,
6. I've said NO to Netgear as it was complaining about no internet,
7. I've browsed to the advanced LAN config,
8. I've tried to change the IP address for the Netgear box from 192.168.1.1 to 192.168.1.253,
ERROR: I cannot change any setting at all, I just a get a "403 Forbidden" frame.
the same happens if I try and disable DHCP, or anything else, or if I change password in the router from the default "password".
so, yeah, I don't know what I could do.
is this yet another bug?
bugmenot2 wrote:well, I'm not trying to use an access point as a router, but the other way around.
While you might be right from the technical view - an Access Point mode not part of the implemented specification. Anything else isn't relevant I'm afraid.
bugmenot2 wrote:8. I've tried to change the IP address for the Netgear box from 192.168.1.1 to 192.168.1.253,
It probaly has changed the LAN IP and the UI can't continue or does not redirect to the changed IP address. Consumer garbage ...
no, it has not changed anything. :(
I can even reboot and it will still sit at 192.168.1.1 ...
I'll probably try with a firmware downgrade at v54 and see what happens.
- antinodeDec 27, 2020Guru
> [...] I don't need to be reminded that an Ethernet cable has two ends.
So you say, but I still don't see where you revealed where the two
ends of your "the LAN cable" actually go. I have what might be called a
"the LAN cable" here, too, but you have no idea what mine might connect
to what.> 8. I've tried to change the IP address for the Netgear box from
> Forbidden" frame.Any "403" error from these gizmos is evidence of a firmware defect.
As it says in the guide, "What could go wrong?" (You seem to have
expanded the envelope a little on that one.) - bugmenot2Dec 27, 2020Apprentice
> to what.
there is a difference between asking for more information and mocking the poster.
you can always ask to be explicit, but if you treat people like idiots they will never like it, whether they are idiots or not.
I had a LAN cable going from either the WAN port or a LAN port of the Netgear (depending on the try, as I explained) and it was going to the LAN port of my main router.
that was evident based on what I said the behavior was on LAN/LAN connections (that is, wired clients were getting the IP address from the DHCP of the main router, etc).
there aren't other ports I could have used on the main router, are there?
if I used its WAN port I would have probably bricked my entire working network.
also, bringing this up again AFTER I've reported that the issue was a badly designed firmware is kind of unnecessary, so I guess you really need to have the last word.
and this should be evident how?
the user manual does not say anything about that.
how should I know that Netgear ships products with faulty DEFAULT firmware?
I thought there was some error on the basic HTTP authentication side that was due to not having reset the password, or stuff like that, and I was going through an endless cycle of resetting the router and changing the password, hoping it would fix itself.
also, how should I know that most Netgear products share this bug, or anything else?
if I don't see a page or thread specific to my model, I treat information with a pinch of salt.
why wouldn't Netgear provide a guide like this, since having it as an easy setup is out of the question?
I have read a lot of threads to get a picture as complete as it could be, yet you pulled my leg in your FIRST sentence talking about psychics... wow.
was that a rethorical question?
I appreciate your deside to help others, but you have a really mean behavior that really stands in the way for (some) folks to be as appreciative as they can be.
believe it or not, I'm no moron and I'm technically proficient, yet I could not foresee that the ONLY way to fix this was to DOWNGRADE the firmware.
if I had the proper firmware on, I probably wouldn't have come here for help and would have made it on my own, no guide needed.
if lots of people have the same issues, maybe the guide isn't as informative as it could be?
for example, it does not say that the Netgear router REFUSES to update the firmware (I had downloaded the v54 IMG file on my laptop) if it's not connected to the WAN, or on the other hand that the Netgear REFUSES to change its IP address if the WAN address has been assigned and it's overlapping, even though that would change with a reboot.
so, again, there might be other steps in your guide to be added, talking about possible firmware updates, or WHEN to connect or disconnect the WAN/LAN or LAN/LAN cables.
bottom line: chill out and thanks for the limited help.
