VashD's avatar
VashD
How to Change Ethernet network name?
When I orginally changed my SSID for the wirless settings, it also changed the ethernet network name that is showing up on my windows 10. I then had to change the SSID a 2nd time (b/c I mis-spelled i...
  • TheEther's avatar
    Apr 23, 2017
    For Ethernet networks, I believe the only way to change the profile name is through the Windows registry.  This article shows you how to do it.
