araheem's avatar
araheem
Follower
Dec 21, 2021
HOW TO CHANGE THE WIFI LOGIN NAME PASSWORD FOR JN1010
HOW TO CHANGE THE USER NAME AND LOGIN PASSWORD FOR JN1010 - WIRELESS ROUTER N150
1 Reply
  • plemans's avatar
    the default login
    login: admin
    password: password
    If you don't know what the current ones are and didn't setup password recovery, you'd need to factory reset to get back in. Push and hold reset for 7-15 seconds while its powered on. then follow the install guide.
    https://www.netgear.com/support/product/JNR1010.aspx
    (please disable the caps lock button, no need to shout)
