belvita999
Feb 26, 2021Star
How to Change WAN IP Address
C7000 Nighthawk - AC1900. Firmware Version: V1.01.34 I am trying to change my WAN IP address (my public IP address, not the private addresses). Some information: I called my ISP and the...
- Mar 28, 2021
No problem. The issue with my setup was that I was using a router/modem combo. To fix my problem, I had to buy a dedicated router, and switch the modem/router combo to only modem mode.
After I had one dedicated modem and one dedicated router, I was able to mac address clone the router (or change the routers MAC address). Once I changed the routers MAC address, my public IP address changed. I can repeat this process whenever I want.
You can buy a router for ~$50. MAC address cloning is the easiest way to change your public IP address.
belvita999
Mar 29, 2021Star
I'd follow this guide: https://www.asus.com/US/support/FAQ/1044003.
But basically:
1. Change the MAC address and click apply.
2. Unplug both the router and modem for ~1 minute.
3. Plug the router and modem back in and wait ~1 minute.
4. Check to make sure your public IP address changed.
Bobbafett
Mar 29, 2021Aspirant
so change the mac and let it process/load and then turn off the router & Modem or turn them off while it loads. i tried just turning off the modem and then clicked apply for clone and turned modem back on. maybe waitng for the clone to finish wouldve helped.. i will try again and get back to you, thanks again for all the help!
