sarvap
Aug 17, 2019Aspirant
How to change WAN to 1000M from 100M?
How to change WAN port to 1000M from 100M? I have directly connected the LAN cable to desktop and I am getting 175 Mbps speed in the Speedtest. But if I connect the LAN wire to router and desktop...
- Aug 18, 2019Dear all,
This seems to be a hardware issue in the router. I've talked with Netgear customer care over phone and they've arranged for a replacement since the router is in warranty period. Thank you everyone.
Ryanbenson93
You will need change the 100mb ethernet cable to a 1gb cable
- sarvapAug 17, 2019Aspirant
Hi Ryanbenson,
As I said, when I connect the cable directly to my desktop, I am getting the fully speed (175 Mbps). I am getting 94 - 95 Mbps only when I am connecting thru the router. I am sure that there is no issues in the cable. The cable is a four-pair cable only.
- antinodeAug 17, 2019Guru
> I have directly connected the LAN cable to desktop [...]
What are the devices at each end of this cable? Are they both
gigabit-capable?> [...] I am getting 175 Mbps speed in the Speedtest. [...]
Which "the Speedtest"?
> Inside the router administration page I am seeing WAN is 100M/full. I
> don't see any options to change this to 1000M or something. [...]There are no such options; the router negotiates its port speed with
the device at the other end of the cable.> [...] I am sure that there is no issues in the cable. [...]
Prove it. As a test, if you connect one of your cables between two
LAN Ethernet ports on the R6400v2, then what do the corresponding
port-status LED indicators indicate?Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for the LED
descriptions.
According to your picture, the LAN4 port also runs at 100Mb/s. What
happens if you test that cable?> [...] The cable is a four-pair cable only.
All eight wires are needed for a gigabit connection. Only (the
right) four are needed for lower speeds.
