supportacc
Feb 28, 2023Follower
How to connect Arris TM1602A to Netgear AC1900 modem router?
I recently had to upgrade my router according to a Spectrum representative, and I was sent an Arris TM1602A modem. I currently own the Netgear AC1900 modem router and have tried connecting them via an...
Feb 28, 2023Guru - Experienced User
IF you have the C7000 modem then you can and need to connect the C7000 to the ISP coax line.
The C7000 is a modem router that gets it's internet services at the coax line connector in back to the wall jack or where ever you see the RG6 cable coax line that comes in the home. The C7000 would replace the Arris modem. You can't connect these two modems together.
Not sure why the ISP service agent didn't tell you this.
