dba31's avatar
dba31
how to connect CM500v modem to cg3000 so as to get wifi and additional lan ports
Hi, I'm reasonably IT savvy but not when it comes to the networking side. I have a CM500V as supplied by my ISP but it doesn't have wifi and it won't connect to a switch allowing more than 1 port be ...
  • antinode's avatar
    Apr 14, 2020
    > [...] I have a CM500V as supplied by my ISP but it doesn't have wifi
    > and it won't connect to a switch allowing more than 1 port be active.
       Because it's a modem, not a modem+router.
    > [...] I need to be able to connect more than just a single device.
       So you need a (NAT) router which you can connect to the CM500V.
    > [...] I have my old CG3000 [...]
       There is a router in there, but it has no Ethernet WAN/Internet port,
    which makes it generally useless to you.
    > Does this make sense? [...]
       The desire is reasonable, but the required hardware is missing.
    > [...] just plugging them in this way doesn't seem to work
       With no Ethernet WAN/Internet port on your "my old CG3000", you're
    out of luck.  A plain-old router (with an Ethernet WAN/Internet port) is
    what you need to use with a CMxxxx (modem).  (Or even a DSL modem+router
    which has an Ethernet WAN/Internet port.)
