donalcorr
Jan 23, 2023Aspirant
How to connect fibre optic cable to router with LAN port
I have a fibre optic cable incoming to an ONS, on the way out of the ONS is also a fibre optic cable which goes directly into a router which has a fibre optic port. The router is Wifi 4 and I want to...
- Jan 23, 2023
Thinking about your reply, maybe what I thought was an ONT in my premises is not an ONT, instead it is just a box which basically connects 2 fibre optic cables together which then goes directly to the router, and maybe the Nokia router has an ONS built into it. So maybe I need to look at buying an ONT, and then plug the fibre optic into it first and then run a LAN cable from it to a new router..... I think that is what you have suggested.
Jan 23, 2023Guru - Experienced User
No. For any FIBER ISP service, there has to be a Fiber ONT device that converts the Fiber optic signal to a ethernet RJ45 port connection. Talk with the ISP about what is needed to be used for there services. They will have this information.
donalcorr
surely there has to be routers out there that have fibre optic ports, but having searched a lot on the net, I can find any.... which is strange because fibre optic is common now, so why are router manufacturers not selling routers with fibre optic ports???
- FURRYe38Jan 23, 2023Guru - Experienced User
That's something that most router Mfr may not have licensing to work with nor want to get into since most Fiber services are handled by the ISP only and may not have the support resources for nor want to support that additional HW at the router level. Most ISP Fiber is handled at the ISP or Specific ONT mfr level. Not a the consumer router level. Maybe but it's still competing with the Cable ISP level as well which is still going strong and not going anywhere anytime soon. There no consumer class router that has ONT/Fiber support here.
So get a ONT then you can connect up any consumer router to it.- donalcorrJan 23, 2023Aspirant
- michaelkenwardJan 24, 2023Guru - Experienced User
What's an ONS?
It isn't doesn't appears anywhere in the 1200 Netgear documents I have filed away.
The again nor does ONT, but at least Google can find stuff, although there are disagreements on the exact meaning..
