donalcorr
Jan 23, 2023Aspirant
How to connect fibre optic cable to router with LAN port
I have a fibre optic cable incoming to an ONS, on the way out of the ONS is also a fibre optic cable which goes directly into a router which has a fibre optic port. The router is Wifi 4 and I want to...
- Jan 23, 2023
Thinking about your reply, maybe what I thought was an ONT in my premises is not an ONT, instead it is just a box which basically connects 2 fibre optic cables together which then goes directly to the router, and maybe the Nokia router has an ONS built into it. So maybe I need to look at buying an ONT, and then plug the fibre optic into it first and then run a LAN cable from it to a new router..... I think that is what you have suggested.
donalcorr
Jan 24, 2023Aspirant
Hi,
Apologies, that was a typo. I meant to write ONT....
It would appear that the Nokia router has an ONT built in as opposed to the ONT being a separate unit.
Regards Donal
Jan 24, 2023Guru - Experienced User
Some ONT mfrs have built in routers with the ONT. Nokia is one I believe. Calis is another I think.
Most home router mfrs otherwise don't have ONT support in there router systems. They leave that up to the ISP and ONT mfrs.
- donalcorrJan 24, 2023Aspirant
That's exactly right, this is why I have now ordered an ONT which I will connect in between the fibre termination station and the new router which only connects by LAN cable. Hopefully all will be good.
- FURRYe38Jan 24, 2023Guru - Experienced User
Would be all you need. Get with the ISP for any ONT configurations that maybe needed from here side.
All you might need after that is a power off of the ONT after you connect the external wifi router to it. Then back ON with both.
Good Luck.
