Misa23
Oct 15, 2023Aspirant
How to connect my R6300 using my mobile device as hotspot?
Dear all I am wondering how I connect my (old but excellent) R6300 Netgear using my iPhone as a hotspot: My iPhone hotspot ---> connecting to Netgear R6300 (instead the usual lan cables) ...
- Oct 16, 2023
If the router has a wires bridge mode, then you could connect it to your phone wifi hot spot signal as a wireless client then you could use the LAN ports in back for wired devices. If the router doesn't then no, the router you have won't work.
microchip8
Oct 15, 2023Master
Nope
Misa23
Hi microchip8
Thanks for your input.
Guess nope means this is not possible and I need to buy another product / router?
Have a nice Sunday
Misa23
